FrankN4 -
Apparently Amsoil agrees with you...I had an email exchange today with Amsoil...Here is what I sent them, followed by their response:
Greetings, I have a small "fleet" of small, air- cooled 4-cycle engines in equipment for my lawnmowing/landscaping business. These include engines manufactured by Kohler, Briggs and Stratton, and Techumseh, ranging from 3.5 to 15 Horsepower. I was going to order ASE to use for the motor oil, when the new MCT caught my eye. In comparing the two oils, Both have the same 4-ball wear results. The ASE has higher Flash/Firepoint figures, but the MCT has better initial TBN. The MCT has better HTHS figures, whereas the ASE has a bit better NOACK volatility figures. For my situation, cold weather operation, and initial cost of the oil are not concerns. I am sure both ASE or MCT would be excellent choices, but I'm looking for that "extra edge" of protection. Which should I use for my fleet - ASE or MCT? Which has the "beefier" additive package?
The response:
Thank you for contacting AMSOIL.
In response to your inquiry, you are correct that both ASE and MCT would be excellent choices for your equipment. The differences between the two oils and their test results are mixed, but the higher TBN and HT/HS results for MCT would only become important for extended drain intervals. Since MCT is recommended for OEM drain intervals when used “off road”, these statistical advantages are not as important.
If cost is not a consideration, MCT is a superior oil to ASE.
As always, please feel free to contact us again if we can be of further assistance.
Conclusion:
I'd still like to know more about the additive package differences between ASE and MCT (i.e., amounts of zinc, calcium, etc.), but I think I am going to go with MCT. Comments?
