I took the sample a little earlier this time because this is the first time I've run Amsoil AMO in this vehicle.
This oil is 8 mths old, w/12,200 miles on it. The vehicle is a 07 Toyota FJ Cruiser w/84,400 miles on it. When I changed the oil last time(12/11), I put back in 4 qts of Amsoil AMO 10-40w and 2 qts of Amsoil SS0 0-30w. A Mobil1-301 full flow filter was installed, and the almost 2 yr old Amsoil EaBP90 bypass filter remained in service on the TopDog V bypass system. No make-up oil, it doesn't use any.
COMMENTS: Base # is SIGNIFICANTLY LOW. Silicon is at a MODERATE LEVEL; Lube mixing is possible due to change in additive levels; replace oil filter and top off system w/fresh make-up oil if not done when sample was taken. Re-sample in 3,500 miles or 65 hrs.
The first #s are from 12 of 2010(17k miles lube time), the second #s are from 12 of 2011(18.7k lube time), and the 3rd #s are from 8 of 2012(12.2k lube time)
Code:
WEAR METALS-PPM
Iron 28....14....12
Chromium 0......0....0
Copper 1......1....1
Tin 0......1....0
Lead 0......0....0
Chrom 0......0....0
Nickel 0......0....0
Alum 5......6....7
Silver 0......0....0
Cadmium 0......0....0
Vanadium 0......0....0
CONTAMINANT METALS-PPM
Silicon 56.....70....43
Sodium 168....45....17
Potassium 4......2.....2
MULTI SOURCE METALS
Manganese 0......0....0
Titan 0......0....0
Molybdenum 2......0....0
Antim 0......0....0
Lithium 0......0....0
Boron 6......4....3
ADDITIVE METALS-PPM
Magnesium 14......11....16
Calcium 3394..3531..4351
Barium 0......0.....0
Phosph 568...497...809
Zinc 691...591...989
V100C 10.9...10.8...12.7
I-R Oxidation 58......64.....61
I-R Nitra 39......41.....17
TBN 2.66...2.18...2.48
Fuel
Soot Vol
Water Vol
As yawl may recall, at the last oil change(12/11) I removed the almost new Amsoil AeA238 air filter element and installed a stock Fram. I also removed the permenent secondary air filter element that is downstream from the replacable elemnt, in hope of reducing the silicone level. It's a little lower now????
Unless yawl convince me otherwise, I think I'm gonna leave the oil and oil filters in place for another 3000 miles/2 mths, then I'll change the oil and filters w/100%(6 qts) Amsoil AMO, the ff filter to a Fram XG8A. I'm gonna change the air filter element back to my lightly used Amsoil EaA238 NOW.
In the future I'll plan to do 15k mile oil and ff filter changes.
What do yawl think?
Don
Code:
WEAR METALS-PPM
Iron 28....14....12
Tin 0......1....0
Lead 0......0....0
Chrom 0......0....0
Alum 5......6....7
MULTI SOURCE METALS
Titan 0......0....0
Antim 0......0....0
Boron 6......4....3
ADDITIVE METALS-PPM
Fuel
Soot Vol
Water Vol
What do yawl think?
Don
