This was my recently UOA while using amsoil motorcycle oil and mixing at a 50%-50% ratio of 10w40 and 20w50. This is on a 2005 kawasaki vulcan 2000 (2053cc-125ci) shared sump Vtwin.
5005 miles on the oil 17,371 on the bike
0.6qts makeup 20w50
alum 6
chrom 1
iron 29
copper 15
lead 6
moly 35
nickel 2
magganese 6
potass 2
boron 1
si 5
sod 4
calc 3413
magnesium 16
phos 1147
zinc 1438
sus vis @210F 73.6
cSt vis @100C 13.89
flashpoint 365
fuel 0.5
insulubles 0.3
TBN 7.5
here is a copy of what blackstone labs had to say about it.
Your mix of oils produced a viscosity reading in the SAE 40W range when checked @ 210ºF. 0.5%
of the sample was gas, which isn't that unusual for a motorcycle engine. It can be from idling or city driving.
Iron and copper improved as did their wear rate (ppm/mile), which is a good sign that no mechanical
problems are developing at 17,371 miles. The TBN was 7.5, lots of active additive left in the oil. Remember,
1.0 is considered too low a reading. Air and oil filtration (see silicon & insolubles) were normal. Try ~6000
miles for your next oil change.
0.6qts makeup 20w50
alum 6
chrom 1
iron 29
copper 15
lead 6
moly 35
nickel 2
magganese 6
potass 2
boron 1
si 5
sod 4
calc 3413
magnesium 16
phos 1147
zinc 1438
sus vis @210F 73.6
cSt vis @100C 13.89
flashpoint 365
fuel 0.5
insulubles 0.3
TBN 7.5
