Amsoil 10w-30, 3177 miles, Pacifica 4.0L 6
Originally Posted By: Gary Allan
Would you mind quoting the owners manual for us??
First of all, both below cited manuals shows the API certification (starbust) symbol.
None of these cars ask for SM oils, but both asked for oil with API Certification seal.
For the Rogue Owner Manual:
Quote:
ENGINE OIL AND OIL FILTER RECOMMENDATION
Selecting the correct oil
It is essential to choose the correct grade,quality, and viscosity engine oil to ensure satisfactory engine life and performance, see “CAPACITIES AND RECOMMENDED FUEL/ LUBRICANTS” earlier in this section. NISSAN recommends the use of an energy conserving oil in order to improve fuel economy.
Select only engine oils that meet the American Petroleum Institute (API) certification or International Lubricant Standardization and Approval Committee (ILSAC) certification and SAE viscosity standard. These oils have the API certification mark on the front of the container.
Oils which do not have the specified quality label should not be used as they could cause engine damage.
For the Odyssey owner manual:
Quote:
Recommended Engine Oil
engine’s performance and longevity.
Always use a premium-grade 5W-20 detergent oil displaying the API Certification Seal. This seal indicates the oil is energy conserving, and that it meets the American Petroleum Institute’s latest requirements.
Honda Motor Oil is the preferred 5W-20 lubricant for your vehicle. It is highly recommended that you use Honda Motor Oil in your vehicle for optimum engine protection. Make sure the API Certification Seal says ‘‘For Gasoline Engines.’’
