On an island beach in in the CT river we saw someone trying to jump a jet ski with a powerboat. Long jumper cables. Saw a puff of smoke from the jet ski and did not watch for very long after that. I did not think it would end well.
I carry a jump-pack with me at all times. They are welcome to use it, but aren't going to hookup jumper cables...I guess you can get in and verify yourself the battery is dead when you hear the starter solenoid click, but I think a lot of people assume the battery is dead when it could be a number of things wrong. Then you end up blowing up someones battery because that's not the problem or, or whatever problem they have transfers over to your vehicle if it happens to be a short circuit or something. Opinions?
I saw an older couple sitting with a flat at a South Carolina rest stop in a Rav4 like mine. I asked if they needed help with the tire and they said AAA was on the way. I wouldn't have offered but I am familiar with the vehicle.I will jump start my immediate family's cars if/when requested but I would be hesitant to do it for anyone else because of liability.
I used to carry jumper cables in my pickup, but now all the cars have a jump box. I don't know enough about damaging electronics, but the cars are far different today.I’m relatively young (32) and have jumped a lot of people around town. Never had any problems from either side of the equation. I don’t see why people are so nervous with jumper cables. Don’t attach them in reverse and you’ll be fine.
Edit: clarity of wording
Jumper cables don’t lose charge. Jump packs are useless if you don’t keep them on a charging schedule, and extreme temps can hinder their performance a ton.I have heard both sides, but with a Gooloo costing like $60 at different sale times of the year, I am not sure why everyone doesn't just go that route.
All true. But if it's in the budget, a jump box is a great solution. Getting cars close enough for cables is not always doable or safe.Jumper cables don’t lose charge. Jump packs are useless if you don’t keep them on a charging schedule, and extreme temps can hinder their performance a ton.
Agreed. I have both in my truck. I just don’t think people should write off jumper cables. Both are useful and at minimal cost.All true. But if it's in the budget, a jump box is a great solution. Getting cars close enough for cables is not always doable or safe.
The common denominator here is you . When things started going South you kept on doing the wrong thing . Hot jumper cables , a power supply that needed external cooling ? Dude , you're dangerous .I posted this story before. Late after work in the parking lot, my boss was trying to jump the Secretary in her old Taurus wagon. He appeared to have enough and asked if I could step in as he had to run. Well I had a brand newish Suzuki Aerio wagon and her battery looked pretty growdy. The whole car was pretty much put a fork in it well done.
But I shut my car off connected all the cables and lastly I was chomping at hard metal bits around her engine trying to get a good ground bite. I started my car and the alternator kicked in hard and the idle fell, but then the ECU jacked up my idle real high. Left that connected for a bit but she still had a weak interior dome. The cables were not warm. Tried to start just a faint click. I wiggled the last ground to scratch under the oxidized aluminum. Finally good bite heard my car alternator load up real hard. Left that for a few seconds and tried stater - it almost moved Try again - almost turning; then I smell it - the cables are smoking! Quickly try one last time and the thing turns over and Starts. Pheew! Yank the Hot off mine fast. Then disco the rest. She says thanks and heads out and I head out.
Well let me tell you I had some licorice warm wires for who knows what reason and that insulation stink.
Drive home, the car ran bad. I said well tomorrow is another day. Nope. Car ran bad. Next day - Bad. I think that week I tried a hard reboot; I lifted both Hot and GND overnight - and it got a little better through the re-learn that week but never like day 2.
After that experience I am not Jumping anybody anymore in my modern cars. Example. My Wife left the lights on her New Subaru one night and it was dead. I said I'm not going to jump her new car - I don't even have cables. I thought for a while and grabbed a Bench 10A 12V supply and hooked that up with some house Romex. That box was getting too hot to touch when charging so I had to bring out a house fan and extension cord to the driveway and blow right on that thing. Romex got hot but didn't smoke. I think I tripled up on it by twisting all three 14/2 leads together to make one "cable". after a bit, miracle of miracles the car started. I told her - go do her errands and DO NOT shut it off. She was good.
So I Learned my lesson hard - Read my lips, Not gonna do It!
There are other things you need to be cognizant about with these newer vehicles. One is that you should not have your vehicle running when you are jumping another vehicle.I’m relatively young (32) and have jumped a lot of people around town. Never had any problems from either side of the equation. I don’t see why people are so nervous with jumper cables. Don’t attach them in reverse and you’ll be fine.
This is exactly why I have a little jump box for each vehicle. Plus there are tons of unhinged people here that I am picky who I help.There are other things you need to be cognizant about with these newer vehicles. One is that you should not have your vehicle running when you are jumping another vehicle.
If you do this can damage your charging system when the distressed vehicle starts, and immediately starts pumping juice out of it's alternator. Things can start burning up fast. Remember you are connecting 2 electrical and charging systems...... And a ton of electronics.
The question was should I give a stranger a jump. My suggestion is buy a $60 jump pack that will work 99% of the time, all but the most unique problems solved. They hold a charge a very long time. Easy to keep charged. 80% of Americans live in areas that do not see extreme cold everJumper cables don’t lose charge. Jump packs are useless if you don’t keep them on a charging schedule, and extreme temps can hinder their performance a ton.
