Altima CVT transmission slipping
I have 2014 Altima tranny slipping slightly when around 60/65 mph. Need quick fix until I have time to drop pan and replace both filters, what would be best product for a slip in like 5th gear
If it is a JATCO cvt try a spill and fill with this;
Don't bother with the filter inside the transmission pan. Do change the small pleated paper filter under the aluminum cap with 4 pc x 10mm bolts on the side of transmission.
^^^this 100%^^^ + i would recommend using either ENEOS or Idemitsu NS-3 CVT fluid. Others may agree or disagree. ( Drain - Fill - 150-200 miles - Drain - Fill )
I wouldn't worry about the filters, worry about the magnets.
Have you used the CVTz50 Android app? It should be able to read the firmware version in the TCU. You can check for updates on the Nissan-TechInfo site.
Any CVT fluid you can buy is probably fine for your tranny. I've used five different products and they all work well. For now just get it changed and the magnets clean.
