I have 2014 Altima tranny slipping slightly when around 60/65 mph. Need quick fix until I have time to drop pan and replace both filters, what would be best product for a slip in like 5th gear
Don't bother with the filter inside the transmission pan. Do change the small pleated paper filter under the aluminum cap with 4 pc x 10mm bolts on the side of transmission.
^^^this 100%^^^ + i would recommend using either ENEOS or Idemitsu NS-3 CVT fluid. Others may agree or disagree. ( Drain - Fill - 150-200 miles - Drain - Fill )
