UPG AGM 'universal' batteries are made In china and often rebranded with extra special marketing and shiny stickers.
https://www.wholesalesolar.com/cms/upg-ub-121000-agm-battery-specs-753736796.pdf
These and the restickered clones do not have a low self discharge like quality AGM and barely any better than flooded
They say to limit recharging amps on a deeply cycled battery to 30 amps per 100Ah of capacity. A rate Easily exceeded if jumpstarted and highway driven.
They do not have significantly higher CCA numbers than regular flooded batteries.
They are sealed. That's about it.
If you want a Top quality AGM, go for Northstar, Lifeline or Odyssey.
Deka intimidator AGM are often relabelled, sold under other brand names in Costco, Sams, and Flaps.
They are OK but, even though they claim deep cycle ability, are only rated for ~1/3 the total number of cycles as the 3 top quality AGMS listed above.
Likely not a factor in an AGM used solely as a starting battery.
I'd recommend holding back and waiting out the Lifepo4 drop in replacements. One single under or overcharge event and these batteries are done. They do not come with adequate high or low voltage disconnects/ battery monitor systems.
Please take all marketing claims with several grains of salt and exercise your inner cynic.
If you want to be a guinea pig/ early adopter of Lifepo4 in automotive use, please come back and give reports over its lifespan.
If you deeply cycle an AGM battery whether intentionally or not, Do not trickle charge it to full. AGMS want higher amp recharges and really really require 100% recharges to perform well, to their full potential. otherwise you will not get your moneys worth.
If DEEPLY DISCHARGED,
Apply at least 20 amps per 100AH of capacity until 14.7v is reached, and hold 14.7v until amps required to maintain 14.7v taper to 0.5% of capacity.
Do this and the AGM will impress you both in engine cranking Juice, and longevity.
DO not do this and there is much less of a chance for that occurrence.
