Hi so I have come across this site in the exhaustive search looking for answers and hopefully guidance.
A little background - I am originally from the UK and own a UK spec 2021 Ford Ranger Wildtrak 2.0L 213PS Biturbo Diesel Auto with DPF and wet belt with 12k on the clock.
I have relocated to the Caribbean (Trinidad & Tobago) on an electrical contract and decided to take my vehicle with me. I have always serviced with Ford and gave her a full service before plonking into the container. After 7 months of being here my engine light has flashed up and after a Forscan check I was greeted with code P253F - Engine oil deteriorated.
Now my issue is that my manual recommends Castrol Magnatec WSS-M2C950-A 0w30 . (also says if unable to obtain then a 0w30 defined by ACEA C2 is acceptable). You cannot get 0w30 here whatsoever regardless of brand.
The Ford dealer here use Valvoline 5w30 and tell me that it is fine to use but I am not convinced as this is the Caribbean where it is common practice to lick your fingers and touch a cable to see if its live
So after all that my question is can I use 5w30? And if so is my engine safe?
I will be changing the oil myself as the Ford warranty only covers the UK.
