It seems like if you removed your PCV valve, your engine would run like it had a vacuum leak. If you have a fixed orifice tube somewhere in the PCV system, that might not be a problem.
Also, giving the PCV the shake test is a huge problem in some cases. On very old cars, the PCV grommet becomes rock hard and stuck to the engine, and the plastic PCV valve would easily shatter.
