- Joined
- Nov 29, 2009
- Messages
- 10,258
Ok so some of you have already read about my issues, but I just wanted to ask for your opinions. I will try to keep this simple. I took my truck into firestone after having my alignment knocked out of whack and they found my truck had bad lower ball joints a bad inner tie rod and a also a dry rotted control arm bushing boot that they mentioned to me, but never gave me a quote on. So basically they can just send you on your way and not even check the alignment? I have a lifetime alignment package. My two front tires are completely bald on the edges in 200 miles. The first two tread lines are bald. That's 500 dollars worth of tires. I'm going back tomorrow cause I explained to the guy on the phone more clearly so now apparently they're going to do an alignment so we avoid what already happened until I can put new parts on the truck assuming they even need them. I have an appointment at a good shop, but it takes them a week to get to people, then probably another week to put the parts on. You would think firestone would at least check the alignment instead of just sending you on your way right? I told them it got knocked out of alignment and they still sent me on my way. Do I have any recourse for my two front tires that are all unevenly worn? I guess I should have complained more at the store. idk. What do you guys think? Or is all this my fault? I just think they would have checked it at least.
