I am surprised this is not being discussed here.
Why?Too loaded a topic.
What is that?They ought to have these on movie sets. In Saudi we had them in front of any structure an armed marine was going to enter.
What is that?
Thanks! I learn something new every day.Discharge chamber. You unload the weapon, stick the barrel in the barrel, and pull the trigger to clear it. I've seen a couple guys drop the magazine, forget to eject the round in the chamber, and fire off a live round into the barrel.
The fact that the gun was allowed to be used with live ammunition, then brought back on set is an egregious error, but even worse is being picked up without clearing it immediately is unforgivable.I listen to KFI Los Angeles on iHeart radio at work. They reportedly said that gun was previously used on the set with live rounds for having fun plinking and target practice.
It’s a terrible tragedy and someone was negligent for not checking the gun.
It should be ONE PERSON with ultimate responsibility and IMO it should be the "weapons master" as is the industry standard so it's consistent from set to set.
If the weapons master "knows" the actor will double-check his work, he doesn't have that ultimate responsibility... because the next actor may not know guns like this one. Weapons Master should assume he's giving the gun to a monkey.
That's not how making movies works, but go right ahead blaming Baldwin for this.He made a fatal error in not checking the gun thoroughly before going on set. When someone hands me a firearm, even when I just watched them unload and clear it, I check it anyway. If he wasn't such an anti-gun snob and actually respected them, he'd know that. When he took possession of it, the first thing he should've done was check to ensure it only contains blank rounds and no live rounds. Then, treat it as if it did have live rounds anyway. He can blame the prop guy all he wants, but he's equally responsible for not doing his due diligence with a live firearm.
This is why I'm a huge advocate of gun safety education classes regardless of someone's stance on them. A lot of gun-related accidents could be prevented with just a little education.
Seems crazy that they would allow any live ammo on sets? I'm sure the better armorers insist on this.I listen to KFI Los Angeles on iHeart radio at work. They reportedly said that gun was previously used on the set with live rounds for having fun plinking and target practice.
