Aisin caliper
CIS
Aisin calipers does anyone know what tool I use to get the slid pins (screws) that hold the two parts of calipers together. I tried a T30 but does not seem to seat all the way in a T 40 is too big
Can anyone help me with this?
Thanks
CIS
Thanks will try that
I did try the T30 torx but it does not seam to seat like I would like it to, the screw bolt not sure what it is called not moving, just don’t want to strip it. I was thinking about using some heat on it?
CIS
You need a TP 30 preferably with a small cordless impact. Watch out for the 2 rubber washers in-between the caliper halves.
So should I not try to use heat the bolt doesn’t seem to move at all. Is it called a bolt or is it called a slide I’m not sure what it’s called
