Air cooled generator. 20w-50?
Apple Valley, California
My wife bought a toyhauler a few weeks ago. The generator is an air cooled Onan 4k. The previous owner was using 10w30 in it.
The paper air filter is pretty oily due to vapors from the crankcase vent being plummed to the air box. Maybe worn rings? Oil hot and thin? Combination of both maybe.
Ran it tonight them changed it's oil. It holds 1.6 qts. No oil filter.
Had just enough maxima 20w-50 to use in it.
Onan recommends 15w40. Supposed to be 108F this weekend and she will be wanting to run the ac unit on top of it.
With the paper filter being oily, by chance had the crankcase been overfilled with oil??
Let us know how the thicker oil works out, I'm having the same problem with my Onan 4KW air cooled, since day 1.
Thanks.
Thanks.
Possible I guess. I plan on rerouting the crank case vent away from the air filter.
I run Amsoil 15w40 Signature series Diesel oil in the Onan P218 on my John Deere 318.
These engines seem to like a thicker oil, in your hot climate, I think the 20w50 will be excellent.
Great idea, this past weekend I disconnected the crankcase vent from the filter housing, connected another hose and routed it out the oil filter drain hole. Ran it for a few hours, all good.
OIL DRAIN PLUG PROTECTION PLATE, not oil filter drain hole.
