Originally Posted By: TinyVoices
The system had not been messed with since 2010 when it was converted to r134a.
This is the key.
If you are not comfortable working on AC, then bring it to a mechanic that can properly measure the pressure and identify the leaks if any.
As easy maintenance, may be clean the condenser/radiator stack and also the evaporator behind the fan.
Although, I suspect, something is leaking with that 17 years age system or the compressor is about to seize or weak.
17 years is a good life by any standard, unfortunately, parts do not last that long anymore.
At the least, there are something internally that needs cleaning.
