My samurai has had the same agm for at least 12 years so I just went to check the voltage using my modified 18650 battery charger as I left my DMM at my parents house the other week. Managed to touch the wrong terminal for a split second and the magic smoke escaped. Now I’m sad.standing voltage of their battery is without the engine running
If I was running an AGM in a vehicle not set up for it, I would keep an eye on the standing battery voltage with the engine off.So, basically how I'm seeing it in my life, seems like you can run an AGM but a solid flooded battery might be just about as good for typical driving sisituations.
All sales and marketing no doubt. A battery is a battery is a battery. Lead falls off the plates from vibrations and poor roads. Sediment tray fills up finally shorting out the cells. Then you get to complain on how bad the old battery was.They handle vibration and heat better and are supposed to last longer.
When did East Penn start making the F-250 trucks?I had that question for my 2015 F-250 PSD. I emailed East Penn. They have a chart and looked it up and said yes. So both batteries in my pickup are AGM from Walmart.
I think East Penn has a chart. They have been helpful with other technical questions.When did East Penn start making the F-250 trucks?
Like I had a question about vanilla ice cream. I called Sony in Japan. Their chart said.........
East Penn makes the batteries. They are not going to tell you no and lose a sale.
I've used AGM in cars from the 80s and 90s and early 2000s. Never had issues. My current flooded Toyota battery (OEM) is 7.5 years old and doing fine *knock on wood* so I'm looking to replace because I'm sure it's getting close to its last crank. Another Toyota flooded is like $130 from dealer. So I'm contemplating that because I don't NEED an AGM. I just like AGMs. They give me warm fuzzies knowing I have the best battery. So now I'm scratching my head more.I think East Penn has a chart. They have been helpful with other technical questions.
If they said sure and you ruined the battery or alternator it would not look good for East Penn.
I put an AGM in a 2015 Forester.I've used AGM in cars from the 80s and 90s and early 2000s. Never had issues. My current flooded Toyota battery (OEM) is 7.5 years old and doing fine *knock on wood* so I'm looking to replace because I'm sure it's getting close to its last crank. Another Toyota flooded is like $130 from dealer. So I'm contemplating that because I don't NEED an AGM. I just like AGMs. They give me warm fuzzies knowing I have the best battery. So now I'm scratching my head more.
Edit: and my wife's Forester has the weakest batteries known to humans. So I've wondered if an AGM would help the horrible lifespan, in my opinion.
Golf clap.AGM has less internal resistance, = less heat creation.
And that is measurable, no discussion about it.
Go asks some offroad/racing forum if they prefer AGM or normal regarding vibrations.
Is it doing ok? Any issues? The websites offer them for the make and model of our cars.I put an AGM in a 2015 Forester.
No, a quality AGM will handle vibrations much better and are much more spill resistant and tolerate periods of non-use better than regular flooded cells. I started flying GA in in the mid 80's, transitioning from flooded batteries to gel than AGM and there is no comparison. AGM's have also given much better service (longer life, less electrical gremlins on the P'cars which are very sensitive to battery quality and condition) than flooded in the toy fleet.All sales and marketing no doubt. A battery is a battery is a battery. Lead falls off the plates from vibrations and poor roads. Sediment tray fills up finally shorting out the cells. Then you get to complain on how bad the old battery was.
Same. Ive run them in 80s/90s care that have smaller, low output alternators. The lower impedance and lower self discharge seem to balance the undercharge and other stressing challenges mbeen using agm batteries in 60and 70s cars for 20 years
