There was a I beleive a question in Popular Mechanics that covered this.When adding an external trans. oil cooler,it is best to put the external cooler ahead of the factory radiator cooler.By doing this the trans. fluid will be a lot cooler but it will also warm up to the proper temp. faster in colder weather and at start up.In other words,splice into the trans lines,place the external cooler on the intake side of the radiator cooler and then hook the radiator cooler up.By doing it this way the trans. fluid will go into the external cooler first and then into the radiator cooler and then on to the transmission.This way the trans. fluid will run much cooler but it will also be closer to the normal opperating temperature without getting to hot.If the fluid does not get up to the proper temp.,the trans does not opperate quite as it should.Just as an engine needs to be at a proper temp. to run correctly so does a transmission.Remember,transmissions also have some of the problems that motors have with condensation etc. getting into the oil.An external pump alone may keep the fliud to cool,this could eventually cause damage.
