My 2014 Altima 2.5L SL has a problem with deterioration of the coating on the RH halogen headlamp reflector.
The RH headlamp is noticeably dimmer than the left headlamp.
Apparently, this is a major problem with the 2013-2015 Altimas, with no help offered by Nissan. Not surprisingly.
http://www.carproblemzoo.com/nissan/altima/2014/headlights-problems.php
I wasted money for new Phillips halogen bulbs before I figured out the problem.
The solution seems to be to replace the entire headlamp assembly, as I believe they are a sealed unit and replacing just the projector(s) is not an option.
With that, I can go OEM for about $500 and perform the work myself and use better halogen bulbs.
However, I was thinking of going with an LED assembly to upgrade the lights.
My question is whether or not there is a requirement to change the wiring harness to support LED lighting?
I read the thread below which is why I'm not using LED bulbs in a halogen assembly.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/5134888/4
