Hi, I have a 2006 Cadillac STS 4.6L V8 RWD 5 speed auto 5L50e.
I recently replaced center drive bearing, flex joints and rear carrier bushing. All torqued to spec. All were worn especially the bushing was shot. I had been getting knocking under the arm rest.
Knocking went away for a few weeks but came back and got quite a bit worse. Upon inspection my new bearing broke completely off it's mount. Could have been defective but I am concerned it may be a transmission issue.
There is very minimal output shaft end play up/down or left/right of the shaft when the extension housing is in place. There is however quite a bit of axial movement in/out. There is plenty of movement all around with the extension housing off. Is this normal? I don't have a dial indicator so can't give precise but it looks like a couple mm axial to me.
I took videos of the play, I apologize for the quality. Hopefully you can still tell well enough from them. Also have a photo looks like some scouring inside the race of the extension housing. The 2 bearings inside the housing seem to be good, no flat spots and spin free and easy, as does the one bearing at the plastic spacer.
If there is too much play end to end can I remedy this by putting in a thicker spacer/shim? If so where can I find those?
Sorry for the long post and thanks for your expert advice.
