Advice needed. 1996 F150, 4.9L
Originally Posted By: TFB1
Maybe at their rated RPM, but once the 302 gets a few revs it's all over for the big I6... Then again that's why they last, rarely rev over 4k RPMs... If a V8 were cammed similar and used high velocity ports(basically poor flowing over 4K RPM), power would be similar if not greater as there are two more cylinders firing for each 360* of crank rotation...
I've driven many work vehicles with the 300, I take the whole motor(V8) any day...
[censored] BITOG can't edit for [censored] around here...
I should have said either one cylinder for 360* or two for 720* rotation...
The 302 lasted a very long time (in my experience they are next to indestructible with that little 3" stroke) and in lopo trim, was pretty much setup as you described above.
I had the nylon timing gears fail on my 300 I6, so I swapped it out for a 302HO from a Mustang. THAT woke the truck up big time.
302 is great for a car. I would take a 300 that makes it's torque down low over a 302 in a work truck anyday. The nylon timing gears were a horrible idea but they only did that on certain years if I recall correctly.
There ya go, I have a friend who has a Lo Po 5.0 in a '88 T-Bird he bought new, NEVER OPENED, now has 357K mi(yes MILES)... Was t-boned maybe three years ago so it's out of service but would probably have 400K miles if it were still driveable, he was commuting around 130 mi daily to work & home...
I upgraded the lopo in my Townie to an HO, that car currently has ~350,000Km on it and runs like a top. I gave it to a buddy of mine and have no doubts that it will easily top 500,000Km with ease
Originally Posted By: Flareside302
he'll be ok.. definitely not preference. it was back-spec'd to 5w20 though.
and as above people have said, look up indestructible. you'll see a 300 I6 (4.9)
They are tough but a good part of the reason is they don't make enough power to harm themselves...
They made a lot of power low in the rpm range which we found great for pulling boats out of the water.
I'd leave it for now, but going forward, if it were me, I'd stick to 5w30 year round. Ignore the 10w30 in my sump - that's the last of a stash from a sale that was too good to resist.
I wouldn't sweat it. I would probably go back with 5w30. Having said that when I had a 300 I ran a little bit of everything. 5w30, 10w30 and 15w40...
Thanks for all of the replies. I'll tell him to use 5w30 next time.
Since he used the oil I had set aside for my Mustang GT, I guess I get to decide if I want to use the Motorcraft or go with something else.
Wayne
