Anti wear additives Mobil 1 & ILSAC, API, Acea, EP/SS.
As it is the oil I currently use I am trying to get a better grip on what is happening with the Mobil 1 line. I know a lot of this has been covered but not fully enough to answer my questions so please bear with me.
It seams that we did not talk much about ratings as the oils we used always exceeded those ratings, so what happens when a rating becomes a ceiling instead of just a minimum?
From what I have been reading here and else where there is concern among the OEM’s about poising of the catalytic converters by phosphorous and sulfur. (ZDDP) Considering the OEM’s have to warranty the cat much longer than the engine it is in their best interest to get this stuff out of oil, the EPA like cats so the EPA is also happy with this. So the OEM’s & EPA made the GF-4 spec through ILSAC an international body.
http://www.ilma.org/resources/gf4letter.pdf
I knew the 5w30 recommendation with blessing of 10w30 and no others in my owners manual was CAFÉ driven but had no idea how controlling the EPA was about it even specifying what the oil cap can say. Basically putting words in the OEM’s mouth.
A little out of date but very interesting:
http://www.northamericanlubricants.com/news/gf4specs.htm
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=11;t=000275
The fuel efficiency gains although any is nice are too insignificant to mean anything to an individual consumer, I would take the gains if they were free but they are not.
Paying for a new cat for me is $1000. Avoiding this is nice but not at the expense of protecting a $5,000 engine that takes a lot more labor to fix or replace, I am also thinking this is only a problem in real oil burners witch is what you are more likely to have with less protection of the engine.
So from what I gather GF-4 and maybe SM are potentially not as good at protecting my engine as GF-3/SL and the only upside is vague protection improvements that took a back seat to the other 2? So these are to be avoided. This knocks out the Mobil 1 SuperSyn line.
Here is some interesting language from the Mobil web site
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_Extended_Performance_FAQs.aspx#FAQs1
If you were to just read the following cold it would just sound like more flowery marketing BS, after reading the EPA letter and the NAL article you can do some reading between the lines.
Looking at this
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=11;t=000274
It appears it is so and has even more than in the older SL versions of Mobil 1 SuperSyn but this only shows 5w30 and 10w30. What about the other 2 EP’s?
The answer I have not been able to find is does API SM necessarily mean ILSAC GF-4, I am thinking yes in 20 and 30 wt’s but what about 40 and 50 wt’s?
Note there is a division in ratings between 5w30/10w-30 and 10w-40/13w-50
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_Extended_Performance.asp
The first two meet ACEA A5 and the later A3, from what I understand the difference is simply HTHS viscosity >3.5 for the more protective A3 rating witch roughly follows viscosity, if so simple enough,
The odd ball is the API separation, the first two are SL makes sense seeing that they do not meet GF-4
But the later two are SM?
Can you have SM without GF-4? If so do they have a reduction in anti wear additives same as the standard Mobil 1 SuperSyn line?
I have not been able to find VOA’s of these two to confirm.
Why I am interested in this point is I drive a larger 4.5L I-6 Toyota engine in a relatively warm/hot climate. The Mobil 1 SuperSyn line is out due to weaker add pack leaves the new EP line
I have no interest in the 5w30 and 10w30 weights. (10.25 and 10.5 cst respectively) except for maybe 10w30 mixed with 15w-50 for winter,
Although straight 15w-50 has worked in this engine with decent #’s in a used oil analysis I think it is thicker than idea at 18 sct. That leaves the impossible to find Mobil 1 Extended Performance 10w40 as my only Mobil 1, has a nice 14.2 cst operating viscosity.
Where do you get this stuff?
If you are still reading thanks, now where am I wrong?
The results of this is XOM reduces the additives is Standard Mobil 1 SuperSyn when it went to API SMquote:
They were being designed to handle a number of issues but the driving factors were emission system protection and longevity as well as fuel economy.
So if your new 2005 car calls for the ILSAC GF-4 and/or API SM you get stuck with the weaker Mobil 1 or potentially loose your warranty.quote:
What's the difference between Mobil 1 and Mobil 1 Extended Performance? Mobil 1 with SuperSyn technology exceeds the latest industry and OEM requirements. It is designed for vehicles under warranty and will provide protection for the maximum oil change interval recommended in your owner's manual or by your oil life sensor. Mobil 1 is designed for excellent low temperature and high temperature operation. It is designed to provide the maximum drain interval as recommended in your owner's manual. Mobil 1 Extended Performance is guaranteed to protect your engine for 15,000 miles or one year, whichever comes first
So Mobil 1 Extended Performance is intentionally not compliant with the reduction in additives but does comply with the only good part of the GF-4 spec?quote:
Does the Mobil 1 Extended Performance meet GF-4 specifications? How did the new specification impact the development of the high-endurance product line? Mobil 1 Extended Performance contains extra performance additives to deliver exceptional performance and protection. This fully synthetic technology is designed specifically for longer service intervals. While it does not meet all the requirements for GF-4, it provides protection of the critical engine parts well beyond conventional engine oils including conventional GF-4 engine oils, and meets all the engine durability and protection requirements for GF-4. Additionally, Mobil 1 Extended Performance oils exceed the requirements of API SL/CF and various ACEA (European) specifications.
Looking at this
