Turbocharged engines are a whole different animal when it comes to the mechanical stresses involved inside an engine. Many of the internal engine problems commonly seen on turbocharged engines are things that you will almost never see on normally aspirated engines. Broken rings are one of those things. Broken pistons are another.
The loss of mechanical (static) compression in a damaged turbocharged engine is compensated-for by increased boost which is capable of maintaining the total (actual) compression to a high enough level where the engine will not miss, this is why it is not throwing a CEL.
