Additive Component Chemisty VII
MolaKule
Staff member
Iowegia - USA
If I wanted a lubricant to "creep," spread, or fully cover a machine part, I would select this agent/component:
Q1: Name the agent
Q2: Explain in your own words what it accomplishes.
This question is not open to Engineers, Chemists, Formulators, or Tribologists.
Swipes and YouTube dumps do not qualify as a valid answer.
Not correct on all three counts, so try again.
It would be helpful to answer with complete sentences. An agent is, a chemical or chemical compound that takes an active role or produces a specified effect.
Q1: Name the agent (The agent is _____________).
Q2: Explain in your own words what it accomplishes. (This agent does this or that).
A little searching on BITOG and you will find the answers, such as:
Mutli-Functional Additives
1. Surfactant
2. It allows the creep or flow by reducing surface tension. If you have ever noticed water flowing on a surface, and have taken your finger and made a new path for the water to follow it begins to also follow the newly wetted trail.
Originally Posted By: Planb
1. Surfactant
Planb submitted the correct response and in so doing receives the BITOG virtual Coffee Mug with the Piston Cup logo embossed.
An older post to which I referenced as a Hint,
Multi-Functional Lubricants stated the following:
Quote:
Surfactants or Surface Active Agents (Protective Additive): family of diphenylamines and amides; usually part of the antioxidant package. Also provides enhanced friction reduction and allows oils to "climb" or spread on and over surfaces. Decreases but does not destroy surface tension
Some call the action, "Creep." In either case, it allows the lubricant to fully cover machine parts that may not get splashed or otherwise come into direct contact with the lubricant..
CVT ATF's have an especially powerful surfactant contained therein.
Also known as wetability or spreadability; the ability of drops of oil to form a covering film. It is influenced by both the lubricant and the surface (material, finish etc). One way of measuring surface tension is contact angle - the incident angle formed by the edge of a droplet and the surface it is sitting on. Oil spreadability can also be influenced by polymer content (and type).
