I might have to tow a ~2500lb trailer across country CA to FL this summer, and I am considering adding a Transmission temp sensor to my A-500 transmission turning a 3.55 rear. It has a lock up torque converter.
Does the temp probe just go in the Pan, or on one of the cooling lines? If in the Pan, where is best?
I do have an additional transmission cooler, and a recently rebuilt cooling system(pump, AL rad,T-stat, hoses), and fresh ATF+4.
I've read how the OD is the weak link in these transmissions, and how one should not tow in OD, but honestly I hate the rpm and engine noise in third gear at 55 to 60 mph, and cannot imagine driving across the whole country in third at those speeds.
Is it the heat which destroys the transmission when towing, or just the stress of the load? If the temp is monitored closely am I still likely to damage the Transmission by towing in the flatlands with the OD on?
The transmission has about 65k miles on it since the rebuild, and has been fed ATF +3 from 10k to 30k miles and ATF +4 since then with many more Pan drops/ filter changes than necessary. I have added a drain plug. It still shifts firmly, perhaps a little too firm from 2-3, and perhaps is a little late/reluctant to downshift from 3-2 without really stepping on it. I usually manually downshift in such situations.
Darn rebuilders did not use the correct fluid initially and I had TCCC/ shuddering issues around the 10k mile mark.
Considering the extra Fuel prices, trailer rental and possible transmission grenading, I am considering shipping the trailerload instead, if the trip becomes necessary.
So, where should the temp sensor go, and do you think it is possible to use the OD in the flat sections of the country without damage?
The 318 was rebuilt 30k miles ago. It runs strong.
TIA.
TIA.
