Can AMSOIL lubricants be safely mixed together?
Answer: Applications require specific lubricant properties to deliver maximum performance and protection. AMSOIL carefully tailors its synthetic lubricants under the strictest quality control standards to provide the required properties for the intended application. Mixing AMSOIL synthetic lubricants is not only unnecessary, it may lead to reduced performance and even equipment failure.
Automatic transmission fluids offer a perfect example. Some transmissions require lubricants that contain specific frictional characteristics to reduce, or eliminate, clutch slippage, while other transmissions may require different frictional requirements. Mixing fluids recommended for different performance specifications may lead to a host of problems, including erratic shifting and transmission failure.
In some applications, mixing lubricants may not lead to equipment failure, but it will reduce performance. For example, if AMSOIL Signature Series 5w30 Synthetic Motor Oil is installed in a vehicle, and its owner adds AMSOIL OE Synthetic 5w30 Motor Oil to top off the engine if Signature Series isn’t available, the vehicle will continue to operate perfectly; Signature Series and OE Synthetic Motor Oil share a similar chemistry, and formulations of the same viscosity can be safely mixed. However, mixing lubricants will shorten Signature Series' life expectancy and reduce its performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
To minimize the risk of performance- and warranty-related issues due to improper mixing, AMSOIL does not recommend mixing AMSOIL synthetic lubricants.
http://www.amsoil.com/frequent.aspx
Amsoil says dont do it.
Some people mix different Brands with no harm done, it is in the realm of possibility that harm will come.
I wouldn't mess with HDEOs buts that's just me, they see much more strenuous variables than regular engine oils.
