Originally Posted By: Seguino
Originally Posted By: sayjac
Advance Auto look-up lists:
Bosch Distance Plus OIL FILTER-DST.PLUS
Part No. D3300
K&N Filter
Part No. HP-1015
Mobil1 Oil Filter
Part No. M1-108
Motorcraft Oil Filter
Part No. FL816
Height: 2.68; Inside: 2.75; Outside: M20 x 1.5
Thanks for checking, but I believe none of these has the 23PSI bypass setting. It appears the OEM is the only one with both the ADBV and the 23PSI bypass.
After seeing the flow vs PSID data from Purolator on the PureONE, I really don't think a Purolator filter needs the 23 psi bypass setting. PureONEs usually have a 14 to 16 psi bypass setting. Maybe the OEM filter does for some reason (ie, more flow restrictive or maybe loads up faster and the PSID increases more due to loading).
