ACEA C3
ACEA C3 is for modern diesels with SCR and EGR, it has lower zinc/phos to avoid build up on aftertreatment, typically 800ppm zinc/phs. I'd rather put in Rotella T5 if you wanted something cheap.
After reading a buyer review I am passing the amazon add says 5litrrs x4 but only one 5litrr jug was delivered.
I will stick to a3
Originally Posted By: 1JZ_E46
C3 should protect just as well as A3. Main difference is that A3 can be ran longer.
Depends on engine type and fuel quality.
Besides the deal not being as good as I thought, I am worried about the low saps, with d4 injection and a timing chain. As well as the gasoline I will be using while in the sticks.I will stick with A3
