wemay
Site Donor 2023
Originally Posted by edyvw
Originally Posted by 2003f7
My Tucson is a 1.6 turbo with D.I.
Use ACEA A3 or C3.
You have Pennzoil Platinum Euro L in Wal Mart. It is MB 229.51 and better than ANY ACEA A5.
better,stronger ex sure but isnt it over kill?
What is overkill? HTHS of Mobil 1 Extended Performance 5w30 is 3, Pennzoil Platinum Euro L is 3.5. That is the most important thing for turbo application.
Also, Pennzoil Platinum Euro L is approved against MB 229.51, which means much better deposit control, NOACK limited to max 10% (Pennzoil Platinum Euro L is GTL based, so in 5W30 application NOACK is probably in range around 7%. BMW TPT 5W30 that is made by SOPUS has NOACK 6.8%. Some argue that Pennzoil Platinum Euro L is actually same oil as BMW TPT 5W30). So, I am not sure you can characterize lower NOACK, deposits etc. as "overkill."
On top of that, Pennzoil Platinum Euro L in Wal Mart is $22 for 5qt, while Mobil 1 Extended Performance 5w30 which is ACEA A5 is $25.
Plus, it's (PP E L) low sulphate ash. Hence the "L" in the name.
Use ACEA A3 or C3.
