Originally Posted By: RF Overlord
Sorry if this is a threadjack, but I have to ask:
Why does American Honda strongly recommend
against doing transmission flushes? I realise they aren't the same units, but the factory service manual for the Crown Vic says that flushing IS the recommended way. Please note that I'm not talking about so-called "power-flush" or reverse flushing or any of the other myths...I assume we're all talking about fluid exchange machines that use the transmission's own pump to do the work.
I think you answered your own question. IMO, many folks wouldn't/don't know the difference between a power flush/reverse flush and the more passive fluid exchange method using the trans pump also shown on a DIY youtube. Thus, to avoid any confusion they just pass on anything resembling the word flush which can mean many things. At least, that's my take.
Originally Posted By: DuckRyder
Actually there is an exact science, it is posted in the Honda service news article which you can see in the attachment on this post on a Honda forum.
http://www.civicforums.com/forums/posts/...571-post33.html
If you go back and read that whole thread what's ironic about that post, is that Honda-99 rejected an acceptable ATF fluid exchange diy youtube method at least in part because the previous poster convinced him that it would damage his transmission if he did a "flush". His actual suggestion was
"just leave it with the old fluid and hope it lasts for a while". LOL
As for the linked pdf, IIRC I've seen that posted here before, but honestly for the average joe diy, not having a lift and going through that procedure even once isn't practical and perhaps more important not safe without a genuine lift. And, I really wonder how many Honda dealerships follow the pdf. procedure with a d&f's?
I found an
actual driving procedure here after a d&f which simulates the lift procedure, but with no lift required. It's basically what I have done, and it's worked fine.
As for the OP, I agree with those that say you're fine. If it's shifting fine, your 3x d&f procedure should lighten up the ATF plenty good for a while. As comparison, I've done single Z-1 d&f's at ~25k interval on a 01 Civic AT and it's still shifting fine at 166k, knock wood.
