AC Recharge Kits
The one I have was v. simple. Gauge tells you if you are low. If low, add until in green. If not, leave it alone you have another issue. Easy and has worked perfectly. At some point it will get a new condenser and lines but this is on my W8 - it will be a grand so I'll take the $40 special at Advance for the few mos. of temps where I need AC.
You seem like a competent DIY,
You may also once in a while when you wash your vehicle to spray some good soapy suds on the condenser and rinse it well. Less mentioned on forums is radiators and condensers will get a film that causes them to slowly become less efficient. Although it is so small most would say "REALLY DUDE" roll there eyes and disregard me. I am use to it. LOL
Please explain how using one of those kits that just add R134A to a system that is low on charge will ruin an AC system. They include a pressure gauge, and even if you're a absolute knucklehead and really overcharge the system the high pressure switch will just shut it down preventing any damage.
There's nothing wrong with a kit like AC Pro, it's just R134A in a can with a gauge and hose to aid in filling. It won't fix a leak but all AC systems leak a little so eventually even with a perfectly fine system you will be a little low on charge.
My buddy charged his Subaru AC with one last month, it was low on refrigerant and short cycling. The gauge on the can apparently wasn't reading right, and you're only seeing low side pressure, so you have no idea what the high side pressure is, and you can't properly diagnose problems reading only side. He emptied the contents of the can, heard a loud pop which came from behind the AC clutch. That cost him a compressor. Not the first time I heard of someone hosing an AC system with this type of a setup. But hey they have plenty of happy customers.
I wish! Her minivan takes a bit over a pound of r134a which ends up being ~$40-50 from autozone with the AC PRO w/gauge.
EDIT: I just saw the walmart link, definitely cheaper there vs autozone.
To double edit my post, I just went to Walmart and a 1 pound can of supertech R134a is $20. That's half the price of autozone......
The gauges on the can are not that great, you also have take into account, the outside temperature. I have a set of HVAC gauges , but if didn't and was sure i was low on refrigerant and wanted to add more without a high side gauge, i would do this.
Pick a hot sunny day.
Have someone else in the car.
Crank it up and set the A/C on max fan full blast.
Attach the adapter to a refrigerant can,( WITHOUT SEALER) Purge the air out before connecting and quickly connect.
Add refrigerant with the can right side up as not to slug the compressor.
Let go of the trigger as soon as the person in the car feels good cool air coming from the vents.
Leave the can an hose connected and put a thermometer in the vent.
If you have 40F-45F Stop.
The above would work if you know you are low, i.e. the compressor is rapid cycling.
IF you are already overcharged the above method will not work.
Gauges are a much better way to judge if you are low on refrigerant.
It's probably a leaky evaporator. But there's a long list of potential problems that this will do nothing to resolve.
By the way this is an "always on" compressor. The stroke length changes but it's always spinning.
This!
Most people only rely on the low side guage but you will be able to do a much better job if you buy a little digital probe thermometer
place the probe into the left center vent at least three inches into the duct.. If the ambient outside temp is about 90 F and humidity is around 50%you should look for a vent temp of about 39-44 F. Monitor the low pressure gauge as well, but you want to aim for those temps 44 F is totally acceptable on a less than perfectly operating system, while adding refrigerant stop when you see the gauge hit 44 PSI or the temp gets to
44 F. That's a general ballpark for most vehicles that use r134a. Also you can check the suction line (large metal lines which are the same one you are adding refrigerant to. Is it cold and sweating at that ambient temp I mentioned, the line should be cold and sweating almost up to the compressor, BUT THE COMPRESSOR SHOULD NOT BE SWEATING OR COLD, if it is you are probably overcharged and high pressure could cause an early failure various components.
My buddy charged his Subaru AC with one last month, it was low on refrigerant and short cycling. The gauge on the can apparently wasn't reading right, and you're only seeing low side pressure, so you have no idea what the high side pressure is, and you can't properly diagnose problems reading only side. He emptied the contents of the can, heard a loud pop which came from behind the AC clutch. That cost him a compressor. Not the first time I heard of someone hosing an AC system with this type of a setup. But hey they have plenty of happy customers. If he was losing refrigerant he was losing oil. Just like an engine. No oil and things blow up
It depends on the specific situation. If you have a TINY leak, you won't lose much oil to become a problem. I have a leak in the discharge hose
and the seal points upwards so the loss of oil is almost nothing at all. Literally a drop or two a year if that. If need be I can get one of those small cans with PAG 46 oil and just add 1/4 oz from that
Well, come across the border to Missouri, because I can get the 12oz cans of Supertech for $5. Autozone charges $6 or 7 per can. Menards also sells $5 cans.
That is the plain can with no tap or gauge.
What fan speed and recirc on or off?
@Chris142 Quote:
That's true, if there was no oil from a big rapid leak or a blown hose or seal, but not when it comes to slow leaks. In the case of slow leaks there's more than enough oil in the system or every car low on a charge would blow up their AC compressor using one of these AC top up kits. All systems eventually lose their charge, through hoses, connections etc. Some sooner than others, which is why these products are so successful. His car took years before it needed a top up, and had no indication there was a leak, there was plenty of oil in the system before he charged it up.
@Snowflake White nailed it.
Edit to add: I have another buddy use one to charge up his VW. He set the gauge to the ambient temperature range on the little dial. He ended up blowing air warmer than when he started. He called me to ask what I thought. I said stop, you might be overcharged. Sure enough he was overcharged, not good. I suggested he bring it to a shop have them evacuate it, and charge it the right way, by weight. Problem solved for him.
Best advice, take it to someone qualified. A good working a/c system will get messed up because of other issues.You could have a blend door issue and a perfectly working a/c system and have little cool air out the vents.
Its not that simple although I guess they would like you to think so as they want you to buy their product.
Why b/c you don't have a gauge on the high pressure side like is being discussed here? I needed some charge, this worked. It's a bandaid.
Well first because the leak (if any) should be repaired. Dumping R134a into the atmosphere through a leak is not good for the environment. And the proper way is to evacuate it and fill by weight.
