- Joined
- Sep 17, 2025
- Messages
- 357
I have a 20 year old SUV. THe AC ran out 3 yearsago or so. Last year I bought an aftermarket can of AC recharge.....surprisingly, it worked.
FOr twenty minutes! Parked the truck, popped the hood, heard it hissing. Looked down (I don't know the technical terms for the AC parts) and one thin long aluminum AC pipe was leaking AC . Hard to say, could be a tiny hairline crack or a pin hole.
Now I seen a few vids where that AC line was removed (need special AC tool line remover) and they did some type of AC braising rod with a mini torch.
I realize not everything can be repaired this way, if at all. I might give it a try, by just removing my engine fans to give me room and better access without removing that broken ac line.
OR...I was thinking of using AC STOP LEAK....some claim that stuff works, even if only one or two years. Others say can last much longer. Depends how bad the leak is and where.
Is AC Stop LEAK a waste of my time?
Is it true that it might damage other components of the AC system, or worse, the motor itself?
