AC Delco PF63 (shown first) and a Supertech MP10575. Both came off my 2019 Silverado. Delco has 5000 miles and the ST has 5500 miles. Both 0w20 Valvoline Advanced.
ST filter. Basically the same, but the ST has a better anti drain back valve.
Ah forgot about that. Switched it up to a Champ PH10063 filter with Valvoline FS high mileage 5w30. Will report back at around 5k miles.Awesome work and detailed write up. What filter went in and on unless I missed it? I Thank You sir. Happy Sunday.
I would love to know that too. Disappointed to see the empty spot on the shelf.Both look good & wonder if there was anything official from WM regarding the MP's.
Looks O.K. I still don't like the loss of media sq in due to the larger E core center tube, other than that gripe, not much to complain about seeing they radiused the outer cage mold so it will now be less capable of acting as a die and promoting tearing of the media.ST filter. Basically the same, but the ST has a better anti drain back valve.
Maybe they are using more pleats (tighter spacing is better) along with the eCore center tube, so the total media area may not be that different.Looks O.K. I still don't like the loss of media sq in due to the larger E core center tube, other than that gripe,
Well at least it's not the vanishing small 6607, or one of the old Made in China Nissan OE with the cardboard endcap jammed against the can walls leaving no ingress area. Makes a good engine killer.Maybe they are using more pleats (tighter spacing is better) along with the eCore center tube, so the total media area may not be that different.
