AC Delco PF1250-15243ES-13:37 - Used oil filter cut & post
Oil and filter changed on 04/16/2016
2004 Ford Ranger 4L V6. Miles on vehicle: 150,432 OCI/FCI: 4900 miles
Out: Mobil Super 5000 5w30 and AC Delco PF1250. No startup rattle was observed with this combo. OCI/FCI 4900 miles. No makeup oil added. I cut the filter open. Everything was in order.
In: MC Premium synthetic blend 5W30 and WIX 51372. It took maybe 3 seconds to fill the filter and galleries. As noted from the startup rattle ceasing. I think I will fill the filter next time.
Problems: gasket stuck to the mounting base. The o-ring on the drain plug stuck to the pan also.
Date Code: 15243ES-13:37 translates to Aug 31, 2015
AC Delco PF1250-15243ES-1337-2 External base plate
AC Delco PF1250-15243ES-1337-3 Internal base plate
All holes in the base plate were effectively deburred.
AC Delco PF1250-15243ES-1337-4 Combo valve #1
Dome end view of the combo valve. The rubber was beginning to harden and take a set.
It took quite a bit of force to remove the combo valve from the body of the filter.
AC Delco PF1250-15243ES-1337-5 Combo valve #2
The imprint from the inlet holes show the combo valve and filter were centered.
AC Delco PF1250-15243ES-1337-6 Media #1
Pleat spacing is even. No media tears. End caps firmly attached.
AC Delco PF1250-15243ES-1337-7 Media #2
AC Delco PF1250-15243ES-1337-8 Media #3
Other filters of this style have nubs on both the top and bottom caps. This one has nubs on the thread end cap only.
AC Delco PF1250-15243ES-1337-9 Leaf spring
Leaf spring and internal view of the can. No rust.
It took quite a bit of force to remove the leaf spring from the body of the filter.
In conclusion, this filter served well for 4900 miles using conventional 5W30 oil. There were were no tears. No startup rattle was observed. No leaks were observed. The filter was over priced in my opinion. However, they can be mail ordered for about $3 plus shipping.
Related links:
New AC Delco PF1250 15125ES cut and post
http://www.bobistheoilguy.com/forums/ubb..._cu#Post4030026
New AC Delco PF1250 (25014520) cut and post
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4023398/New_AC_Delco_PF1250_%2825014520%29#Post4023398
New AC Delco PF1250 old design cut and post
New WIX 51372
http://www.bobistheoilguy.com/forums/ubb...ut_#Post4009590
Unused CarQuest R85372-A43301
http://www.bobistheoilguy.com/forums/ubb...cut#Post4002381
Unused Champ PH820-011514ES1
http://www.bobistheoilguy.com/forums/ubb...d_c#Post3998005
Unused Motorcraft FL-820S-909031527
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3997575/Motorcraft_FL-820S_Date_code:_#Post3997575
Used (Torn) Motorcraft FL-820S-904121217
http://www.bobistheoilguy.com/forums/ubb...Dat#Post3994569
Used Firestone TF4651-092314ES
http://www.bobistheoilguy.com/forums/ubb...Dat#Post3994624
Related links:
New WIX 51372
