Hello all. I am new to this forum and have discussed this issue over in the diesel forum. A member from there suggested I post it here for awareness and discussion. Here is the information:
I always used Fram filters but have been seeing more people with problems with them so I figured I would switch to AC Delco filters. I buy the filters from Amazon and here is my experience to share:
This filter comes in the box and the tag on the filter says PF1218 (GM# 25160561). My application is for a 97 Chevy K2500 with the 6.5L Diesel engine. Once I installed the filter and started the truck I had 0 (zero) oil pressure. Waited a few seconds and still nothing shut off the truck and waited a few minutes - tried again - same result. So I purchased a Fram PH5 which is the replacement for the PF1218, within 3 seconds of running I had oil pressure. I then compared this PF1218 to the PH5 and it is obvious the trouble - it does not have a anti-drain back valve and the supply holes (the ring of holes punched in the filter) was not in the correct place at all. Had I not paid attention I would have ruined this engine that cost over $4,000 to replace. Beware and use caution if the filter you are replacing does not look exactly like the old one - don't use it. I believe someone at GM (AC Delco) is making a mistake and putting the wrong tag on the filter. It is clearly the wrong filter.
Now some will say the difference in the filter is obvious - however I have never used an AC Delco filter before and thought it was just a design change due to the Fram fitting more applications.... WRONG!
I am not sure if I am allowed to link to other pages on this site but will try and am sure I will be told otherwise.
Here is the original discussion post: AC Delco PF1218
And here are the pics if this works:
Now I found out that the problem filter I actually got was similar to this one from Champs Lab only badged for AC Delco:
Just thought I would post this up for discussion here. And please understand I am not advocating Fram over AC Delco - - - just trying to provide some information. If I had not paid attention to oil pressure gauge and saw the mistake - chances are I would have ruined an otherwise great 6.5L diesel engine - which as you know is not cheap to replace!
