Originally Posted By: dishdude
Originally Posted By: Sayjac
What's curious about the link information is the factory filter at least on some GM is the PF48. However on the filter it says, replace with PF63 right on the can. There is a thread by car51 showing this but unfortunately the pics are now gone on tinypic and thus bitog, though the thread is still
here .
So I'd add if they get confused, part of it is because the vehicles come from the factory with one filter # but say to use the other, the PF63/(E).
And this information would be specific to ACDelco. The media on aftermarket filters would not be the same, thus the bypass spec wouldn't necessarily need to be the same. And if GM required the ACDelco PF63 only ie., no aftermarket, they would have to pay for it.
iirc, GMBoy (or someone else with inside knowledge) said the shorter PF48 is used during the assembly process because the longer PF63 is more likely to be damaged during engine installation.
That was me and is correct. I just came across this information and was a little perplexed. I will have to see who I can call and get a more clearer understanding.
