MolaKule
Staff member
...It's also a mystery whether (1) the GM TechLink report was wrong or (2) 88861800 has been reformulated since 2006.
The differences in formulation is no mystery and to your comment I would say, "Take your pick."
Clearly a "cold weather specification" requires a minimum KV100, otherwise a fluid could be super thin to perform well cold, but not be thick enough when hot. I agree with you about that. But edge10 and I have not misunderstood the J306. I repeat, "unlike a grade of 75W-85, a grade of 75W-85W has no indication of maximum kinematic viscosity at 100C." Why not grade fluids with both a minimum and a maximum KV100? The grade 75W-85 accomplishes this, and 12346190 could have been graded in a similar manner, although we can't be sure what the final number actually is.You are quoting someone (edge10) who has the same misunderstandings as do you. The "W" designation indicates the cold weather specifications, so the minimum specified viscosity only makes sense for the cold weather specification.
Nowhere, which is exactly the point. That's why I claimed it was "abusive" notation. Its meaning still isn't clear. Why two "W" gradings? Your justification below may be plausible, but I still find 75W85W quite odd and ad-hoc:Where in the SAE Gear Oil charts or specifications do find a 75W85W?
I think the "W" suffixes were possibly meant to convey slightly better low temp performance specs and possibly lower pour points.What is the design goal for specifying an oil with two low temp grades such as 75W-85W?
That's the one I inserted between Photo 1 and Photo 2 in Post 3, although I didn't have the Canadian part number.Just to complicate matters even more, here is one more, with a Canadian part number. It has a "special polymer friction modifier," apparently.
Not Pictured:
Synchromesh Transmission Fluid - Friction Modified
USA:88900399, formerly 12377916
This has a different friction modifier than that contained in the one above.
Amazon.com
Both GM MTL's have synchro Friction modifiers but the later MTL has a special polymer friction modifier.
I’ll check next time I’m in. They’re not cheap, but they are at the parts store and not limited to the dealership.@Snagglefoot, what prices are you seeing on these fluids?
I am not sure what why a so-called 75W85W thread from 2008 was brought into a thread which simply pictured three different MTF;s.
But, I did find the original Edge10 thread here from 2008:
https://www.bobistheoilguy.com/forums/threads/75w-85w-correct-lube-spec.90238/page-2
edge10 said:My 1994 Mitsubishi specifies either a 75W-85W or 75W-90 GL-4 for the transaxle. I am questioning if the 75W-85W is a misprint since there are 2 low temperature viscosity numbers . Should the correct spec be 75W-85. ...The 75w-85w appears several places in the Dodge/ Mitsu service and owners manuals. If it is not a misprint I think this is a silly spec. Yep, the Nissan OE fluid is a ripoff unless you go mail order, which is 1/2 a ripoff - at about $US 8 a quart. I probably go with it though, since I am looking for a mineral base oil and can't find Syntorq that easily.
It was never determined if he misread it, or if there was a misprint in the manual, as we only had his interpretation of what he read, because much of his text wasn't very explanatory.
If the manual actually stated a 75W85W then I would have to say it was a misprint because I have yet to see a 75W85W specification because it really doesn't make any sense.
If anyone has a pic of a bottle of MTF with 75W85W labeling or a copy of the Dodge/Mitsu owmer's manual, then please upload it.
We're discussing 75W-85W because 10953477, photographed by the OP in the initial post of this thread, is labeled as such. Did you miss that?I am not sure what why a so-called 75W85W thread from 2008 was brought into a thread which simply pictured three different MTF;s. ... If anyone has a pic of a bottle of MTF with 75W85W labeling or a copy of the Dodge/Mitsu owmer's manual, then please upload it.
I should hope so. I've been linking quotes from that thread.But, I did find the original Edge10 thread here from 2008:
As I previously stated, I thought it was a typo on the AC Delco bottle, until I found the thread you linked, and others on other forums, that discuss 75W-85W. It seems not to be a misprint, just a strange grade.If the manual actually stated a 75W85W then I would have to say it was a misprint because I have yet to see a 75W85W specification because it really doesn't make any sense.
I took these shot today. They are in Canadian dollars. Multiply by 0.7 for US dollars.@Snagglefoot, what prices are you seeing on these fluids?
I appreciate you taking the time to take additional photos. This really confirms the "unicorn tears" hypothesis:I took these shot today. They are in Canadian dollars. Multiply by 0.7 for US dollars. Comparatively, Dex VI is cheap.
49CAD is about 37USD at current exchange rates. That's a lot of money for a quart of fluid. By the way, if you don't mind me asking, assuming this is a chain store, which chain is it? It seems quite well-stocked.P/N 12346190 [Canadian 10953477] and the Chrysler equivalent are made from unicorn tears. ... Looks like that's not the case now, but at $32 a quart it still must be made from those tears.
Thanks.Lordco Auto Parts. Very big in British Columbia. Every large town and city has one.
Sounds like a one-stop-shop.By the way. Lordco stocks Motul. Only store around that does that.
The USA part number for Canadian 10953477 is 12346190, listed on Amazon here:I went to the local GM dealer and requested a quart of A/C Delco 10953477
Interesting. Someone on Amazon Q&A also contacted the local GM dealer and was told that 12346190 (Canada 10953477) had been superseded by 19369226. The latter bears the same name (Manual Transmission Fluid), but is 75W-90. See these sites:was told that number is no longer valid and has been superseded by A/C Delco #88861800 (10-4033
https://www.amazon.com/ask/questions/Tx2GXURB0F9DSD/ref=ask_ql_ql_al_hza said:I called my Gm dealer and asked them if they could get 12346190 and they told me it had been superceded to a new part number 19369226
https://www.gmpartsdirect.com/oem-parts/gm-synthetic-manual-transmission-fluid-gl-4-75w-90-32-oz-19369226 said:19369226 ... Replaces: 12346190
https://www.amazon.com/ask/questions/Tx2GXURB0F9DSD/ref=ask_ql_ql_al_hza said:The bottle I received says 12346190 [Dated March 6, 2019]
That's what I though too, which led to the following interaction:While some MT fluids may be labeled as 75W-85W I still maintain it is a non-sensical labeling.
The 75W-85W label seems abusive of the labeling standard.
You're making quite a few allegations here ... what are these labeling standards you speak of that seem to have been abused? Do you have a labeling standard that you can point to?
