Originally Posted By: Big_Ed
I'm not really worried about the strength of the cage, I'm wondering if the extra wide open spaces between the rails of the cage would allow the filter media to flex more and possibly tear apart under high pressure situations (such as a cold start up), and possibly blocking the oil outlet hole of the filter, or going into the engine causing damage. The "old" technology has worked for many decades. Why change it? Where's the benefit to the consumer? I bet it benefits the manufacturer by being cheaper to produce. Where were the failures or problems with the "old" filters that required a redesign? Not a necessary redesign. If it's not broken, don't fix it. (And it wasn't broken) It just sounds like a cost cutting measure to me. I've started hoarding the old-style filters for my GMC.
If you trust the Ecore design, that's great. I'm happy for you. I just don't trust it. And I won't use it as long as I have a choice.
It is the same center tube design as the increasingly popular cartridge filters. It would be hard to miss it when you changed it if one of them imploded. They certainly should give as much support as the filter where the metal tube doesn't run fool length of the element.
I think there was some discussion of metal particles getting into the filtered oil from the perforations in the metal tubes.
Yeah, maybe they are cheaper. So is moving the factory to china. Ecore, American engineers working smarter to keep jobs in America.
