I think this is just a design flaw on my 2015 Tacoma but maybe you folks can toss some ideas my way.
As the title states, if I'm sitting at a light or parked, the AC blows "cool" but it usually isn't cold enough to keep up when temps outside are 95+. Once I get moving, it blows plenty cold.
I guess it's just an airflow issue with the condenser? I have not had an A/C shop check the charge level since the system can blow cold enough at the right speeds, so I assume the charge level is correct.
Could I add supplemental electric fans or anything to assist with moving the hot air out from the engine bay?
