my uncle has a 02 sentra gxe 1.8l and it has a A/T.
It has about 30k miles on it. He drives very short trips to work and back.
The car really is in bad condition hehe
i change his oil every 3k-3.5k miles. I use whatever i can. Usually the car had Castrol GTX 5w30 and fram filters.
But then i also used Supertech 10-30 hm synthetic with supertech oil filter and now its on valvoline maxlife syn blend 5-30 w. supertech oil filter.
The sump only holds 3qts and when i changed his oil after the supertech 10-30 hm it looked like sludge but it was still very liquidy.
Also as i looked down the filler cap i saw that the cam had some kind of wear on it. Weird. But i know that no more supertech oil for this car.
another thing, i change his oil not every 3 months but by mileage.
So typically this is around 5-7 months.
His A.T fluid has never been changed.
His trans sucks!
it changes gears at slow rpm's just fine but when your speeding it either jerks into 2nd gear or it almost seems like slipping a clutch so i assume torque converter is not great.
I believe i will have to drop the pan. I have done this before in a 96 cavalier with great success so im confident in doing this,
Should i use OEM nissan fluid?
i can get it at a local store.
Hopefully this will solve the transmission problem.
ANd i was thinking about using Auto rx but seeing that my uncle does not care about his car... I mean his interior is FILTHY!!
He never checks under the hood. Last time i was changing his oil i had to fix his flat because he was driving with a flat with a BABY on board!! He comes to me saying his brakes are making a noise and he had no more brake pad life left and killed his rotors. So i changed it all for him. Talk about a moron.
i keep on insisting for him to get another car and sell this one before he kills it because with the way thinks are going , either his engine will die on him or the transmission will and he will have to dish out alot of money.
sorry for the long post but i just had to get it all out of me.
His trans sucks!
