Absolute longest lasting oil filter?
I misspoke, he has been using a Fram Ultra. I'll have to read more about the relocation kits.
+1
Do the job right or just pay to have it done by someone who can.
Not an oil filter problem.
Bullwinkle: those 3.5's and 5.0's have the filter mount right above the 4wd pumpkin. Stupid design as I've let them drain over 15 minutes and they still drip and oil changes on em' ain't fun. One of Fords not smart ideas
Originally Posted By: fdcg27
+1
Have you ever taken a filter off on one of these trucks?
Don't own one of these trucks, but if I did I'd change the filter at every OCI just like I have with everything else I've ever had.
Some were harder to do than others, of course.
If I owned one of these trucks; I would do what my friend that has reg cab one and run a quality syn like M1 and a FRAM ULTRA #10575 for 15k. The oil changes on these vehicles are a nightmare; I should know as I have worked on them and replaced throttle bodies on them. People that work on them know.
Originally Posted By: PeterPolyol
MANN+HUMMEL, MAHLE and filters of equivalent quality. No gimmicks, no slick marketing campaigns, no really bad gimmicks, no little mystery gimmick pads, just quietly doing work in real world OEM extended OCIs before they were cool.
I've had more start up rattle with multiple Mann+Hummel spin ons than any other filter on the old A4. This is a shame because I really like their construction and price. Does it really matter? I do not know. I had the same issues with a Napa Gold I bought on sale last winter.. and it came out looking like junk after just under 10,000 miles.
I am using the smaller M1-204. 3000 miles so far and all seems well.
Here's the Napa Gold.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3995077/Napa_Gold_51355_cut_open
Regardless of how the start up rattle was, the Mann+Hummels always came out looking new but "used."
With all the concern about pollution and vapors, having oil burning off and dripping on the ground for days is worse than some of the regulated things. I had cars like that, one was a Honda. I used to put newspaper cardboard, foil, whatever to try and guide the oil into the pan. It is extra work and most people aren't going to bother. But the result is clean parts under the filter. Any of the high priced filters have higher holding capacity. I probably would go with a RP or Ultra.
Originally Posted By: ZeeOSix
….. I usually make a drip shield out of heavy duty (ie, thicker) aluminum foil that will catch the oil from the filter and drain it into the oil drain pan. Works pretty slick because you can fashion the shield as needed.
I've made oil drain shields in the past for various vehicles out of aluminum roof flashing (from Lowes, Home Depot, etc). Works very well, even under the drain plug.
Fram ultra's probably best filter for money specially when bought in sets of 6 on eBay. I bought 6 xg8a's today for 25$ shipped.
I have/had 2 of these trucks for well over 100K miles combined. I can change my filter and have no drips so it can be done, I use 10k premium filters. I have a really nice brick driveway so drips would be a big issue for me.
I have no issues with it dripping on my front pumpkin either. However I do give everything a quick wipe down when I am done.
Originally Posted By: AirgunSavant
as said "Ultra"
Agree, and OP also mentioned Amsoil, which is at least 15k, and up to 25k/one year depending on which one the vehicle uses.
A bypass setup would also extend the amount of time between filter changes.
OP -- what's his reason for wanting to make the change? (just curious...)
The 25k Fram "Toughguard Ultra" Hah, but I doubt it. The good, better, best marketing strategy they got going on is unlikely to change anytime soon.
Only way to make your Ford stop dripping oil in your driveway is trade it.
Change the oil and filter at the recommended interval.
I think the Amsoil filters are rated at 25k miles or something like that. Using a filter that long is crazy IMHO but whatever floats your boat I guess. I always found a can of brake clean and a couple old shop rags eliminated the oil drip problems on those F150's just get up there and wipe the tray out under the filter.
Get a FRAM Ultra, install with a 500 ft lb. air impact wrench using red lock-tite and forget about it.
