ABS scanners that are cheap but good
Arlington, Washington
I know oxymoron......
But I had to ask anyway.
Actron (ACTCP9449) ABS BrakeScan Scan Tool # CP9449
I see Amazon want's $127 for this unit. JCWhitney wants $300
I want something cheap that works......
So, you are saying you want an inexpensive, decent ABS scanner? A cheap one will be just that: cheap. I don't know either.
I see an Innova scanner that does OBD II engine codes, trans codes, and ABS codes for $200 range. I have a OBD II engine scanner but might consider a scanner that does the engine codes, trans codes, and ABS codes if the price is right.
I don't want junk but am not rich and don't need pro quality.......
Originally Posted By: Vikas
Innova will only do domestic ABS scan
I noticed that as well.....
Can you accuate the ABS module for brake bleeding with the Innova 3160? Or just read ABS codes only?
