abs light
indiana
Abs / brake and trac off light is on after changing rear rotors and pads took it and had it scanned at the auto parts store
They said code 10 came up - over ride control module power source missing... what does this mean?
Thanks for any help you can give me.
2005 town and country 3.3
I don't know what a "code 10" is in regards to the ABS system, but if that work was just done on the brakes then my first suggestion is to look for disconnected wires or damage that may have occurred during the maintenance. Also if a "power source" is missing, check the fuse for the ABS system.
Abs / brake and trac off light is on after changing rear rotors and pads Start there.
