Originally Posted By: virginoil
It is possible to measure mpg down to 0.2, I have done so for many weeks when I choose to measure the mpg.
If all things being equal and the only change was the switching of the oil brands for a season and the mpg went back to normal after the switch back to the usual oil brand then the OPs claims are valid, and you don't need a LAB to confirm the result.
That is not correct. In real-world driving it is impossible to isolate and measure any one variable, especially one as small as the impact of motor oil. There was a good article a while back about making real-world fuel economy measurements that detailed the legion of variables that have to be controlled, first off it can't be done on city streets it must be done on a test track. And you must use standardized test fuel with a consistent energy value since everyday gasoline varies far too much to get any useful numbers.
The isolation of variables becomes more difficult but more important as the variable effect gets smaller. The wide noise band (as Garak notes) of real-world driving masks a lot.
