AA/AAA battery charger suggestions?
Originally Posted By: Vikas
Tell me about the eneloop pro; this is the first time I am seeing them in pictures. How do they compare with the regular eneloop?
The Pro has more capacity (2450 mAh) compared to regular eneloop (1900 mAh). The Pro also seems to have slightly lower internal resistance, which means slightly quicker recycle times in my external flash.
The downside is that the Pro can only be recharged 500 times vs 2100 times for the standard eneloops.
FYI, this is a lower cost option: http://a.co/iCQ8BS4
Same performance/capacity as Eneloop Pro.
I like/use the Opus & Xtar chargers mostly.
Stockings - check out Olight USB charger. Very compact. I like I can use it in the vehicle traveling. Low $
