I hope this is the right place to post this question. I think I brought it up last winter but maybe that was a PM or email.
See also "Is it alright to cover your radiator in the winter" by 2003TRD...but THIS post deals more with how, in theory, to get more heat coming from the actual combustion process...here goes...
It's the cold of winter. Say -20 or colder. The cold is getting to you and the car never really gets warm, even in 30+ mile trips. Would this work, has anyone ever tried it, and how would you test it?
What if you used higher-octane gasoline? Not for more horsepower; not for better mileage. For more heat.
I confess I have just plain forgotten; does higher-octane actually burn slower? Or contain more heat energy, potential heat, BTU's, latent heat, etc? This is important to the theory, at least in part.
What I am thinking is, the air-fuel mixture is ignited and the flame front propagates as it pushes down on the piston. If the flame-front propagation is slowed / lasts longer by higher octane, or is just plain inefficient due to cold weather, would it not cause more heat energy to go into the coolant, and wouldn't THAT lead to higher temperatures in the coolant jacket / heater core?
Is my theory moot unless the block or block + radiator can be covered in insulation? Is it moot as long as ambient temperature is so low that gobs of heat energy vanish into the air anyway?
Your thoughts are welcome but I'm hoping for more scientific replies
Thanks!
Rob
Thanks!
Rob
