It's just a mirage.
Not a Mirage.
It's just a mirage.
Wow, and it was an immaculate one too! Good catch.Last time gas got this expensive I saw the first Chevette that I had seen in years. In fact two of them in different parts of Maryland.
The Justy CVTs make the Nissans look bulletproof. When going bad, slowing down to a stop they would "downshift" so abruptly that the tires would chirp and your head would almost hit the windshield.There was the short-lived Subaru Justy 3 cylinder. I think that may have been the first CVT model sold in the US.
XFI models were desired for their high mileage
I miss fuel economy specific trims
XFE, SFE, Civic HX w/VTEC-E
My 25hp Subaru 360 was all those things and more but far more smiles per mile than anything you might ownWas not fun to drive but cramped, lacked power, too close to the ground and an overall a poor example in its class.
Unless it’s a grey market import, a 3 wheeler or your not in the USAI'm currently in a rental driving the modern day equivalent...yes, there's a 2021 car with a 1.0L 3 cylinder putting out 67 hp. Details to follow...
I learned stick-shift on a 1983 Civic 1300FE. The "FE" stood for "fuel efficient" which meant it had the smallest engine equipped with the tallest gearing, in an era when many cars still came with 4-speeds. I am sure its complete lack of power options, sound deadening, insulation, armrests, radio and all other creature comforts kept its weight down too and was part of the FE package. In the days of the 55-MPH speed limit, we could easily get numbers in the 60s; the numbers I remember calculating a few times was 63 or so. It was carb'd, yes, and as such would become tricky if not impossible to start in bitter cold weather. One solution we tried on a few times was to raise the front of the car on ramps and place a BBQ grille with charcoal smoldering in it below the engine. Depending on how windy it was, sometimes that worked.On super great fuel mileage models of the past, I'd have to add the 80's Honda CR-X, both the regular model and the HF. I knew a young couple in the 80's that had a CR-X HF. Actually, friends of friends. They had a new HF and ran it for years. They claimed that 60 mpg was a given for them and they had seen 65 mpg.
Guy I worked with loved his Metro. His commute was about the same, he NEVER got less than 40 mpg. It was still running fine when the front subframe would pass inspectionWorked with a guy who had a 125 mile a day round trip commute. This was before the Prius, and before telecommuting. He would pick up a first generation stick shift Geo Metro two door as cheap as he could, and then run it into the ground. Then, he'd sell it for scrap, and find another one and repeat.
At a different job, worked with a guy who did the same thing with first generation stick shift Neons. He got to the point where he'd swap engines and transmissions himself in his driveway, if the car was still worth it, instead of junking them. He and his wife both drove them.
