So im on vacation last week and notice my Silverado feels a little doggy, like im dragging a anchor.. Then a day later i hear a grinding noise (for only a few seconds) from the front end.. I have plans and simply dont have the time in the vacation schedule to start looking for noises.. So i call my dads favorite mom and pop shop, a appointment was made and the truck dropped off.
They call: "We cant find anything, your trucks pretty much in perfect condition and all your fluids look brand new"... I think to myself of course they do , im a BITOG'ER..
I pick up the truck and make it halfway home, it still feels doggy and 3 miles away it makes that awfull grinding noise again.. i bring it straight back to the shop..
The next day i get the call, "Did you do a brake job yourself" (yes) "did you lube the pins on your callipers" (errrr..no) They seemed perfect and i took the shortcut.. No i did not lube the pins.. Well, your front left calliper is dragging, thats probably the doggy ness your experience, i ask them wouldnt i hear a noise if it was dragging, Not always He askes, did you notice it pulling a bit to the left ? (Yes) that would explain it.. Also, your right front hub assembly is going bad, there is play and with a stethascope noise can be heard.. Ohhh..
Sir you need new rotors as you had the old ones turned and if we turn them again they will be below spec.. you need pads now as one side is shot, and you need a new hub.. OUCH...
The good: The shop did all the legwork, they had my previous pads warranty done for me so i got a fresh set of pads for zero dollars, Since they did not detect this stuff the first time around they gave me a price break on parts $100 appiece rotors for $80 each, the $360 hub for $300
They lubed the callipers, new top end pads, new top end rotors, new Hub assembly, topped off fluids (and yes they actually did) and all the labor for $680.00
And they were pretty cool to deal with as well..
eveyone has negative shop stories, i had a decent experience..(minus them not figuring it all out the first day) and my own brakejob shortcut 2 summers ago led to the new work needing to be done.. Yep my fault..
Thought i would share.. P.S my trucks picked up 2.5 mpg on the computer and drives like pure silk.. I checked all there work and im completely satisfied.
