Originally Posted By: JHZR2
Originally Posted By: bvance554
Originally Posted By: Colt45ws
Originally Posted By: 79sunrunner
from spazdog "It's just to run hot dry summer air over the evaporator core for a little." Thats the same reason I shut mine off 5 miles before I reach point B while driving.
lol, I'd run my A/C about once a month if I did that.
There is no reason to do this. Even on older vehicles the compressor should be on a circuit not hot in 'start' so it wont actually be pulled in during cranking. On modern vehicles its computer controlled so even less point.
5 miles is a bit much for me. But, what he is speaking of has nothing to do with computer control and starting. Rather drying out the condensor to reduce mold.
I dont believe it dries the evaporator (condensor is outside) at all. The coils are cold, so they will still condense moisture when you turn off AC. Then youll have a wet environment. Unless youre in the desert, likely there is a good amount of humidity, so what will happen is youll have saturated air in the coils, because of the humidity coming in plus the moisture in the closed area. It is a very slow process to actually dry it out by flowing air, and there will always be a ton of humid air passing through.
In theory, maybe, but in practice I noticed that shutting off the AC a mile or so before arriving does reduce moldy smell.
When my wife and I commuted together in our Mazda 3, I was behind the wheel most of the time and I was shutting the AC off just before arrival, unless it was really hot and humid.
Now we have two cars and Mazda 3 is my wife’s daily commuter. She never shuts off the AC and on our last trip together she even commented that the air is starting to smell moldy when AC is used, I noticed the smell too.
From experience, I think that shutting the AC off, at least in Southern Ontario, does reduce bad smells coming from the vents.
