- Joined
- Feb 6, 2025
- Messages
- 806
2000 Buick LeSabre but 2000 thru 2005 is all the same car.
A/C compressor is clattering pretty loudly with the clutch is engaged to run the A/C.
Vent temperature is down to 86 degrees while it was blowing 41 degrees last week. Ambient temps over 100 for both readings.
Tried adding refrigerant, but it was already well within the green zone which is 35 to 45 whatever those numbers represent.
I think the compressor is toast. It had a pretty good run. I installed it in 2005 shortly after I bought the car.
The replacement compressor was an ACDelco from a local parts house that is no longer in business.
The factory compressor was not making a clattering noise when I replaced it. I replaced it because it was not providing suction they told me.
I was thinking about going with a Bosch unit. I've been very happy with their new alternator.
The plan is to replace all the parts myself and then hire a shop to charge the system.
Which brand of compressor and condenser would you recommend if OEM is not available?
I normally go with RockAuto for expensive parts like that.
