Well, I swapped in a known good R4 a/c compressor in my 1987 Olds Cutlass 442 to replace a working, but noisy compressor thinking that compressor was going bad.
Unfortunately, the replacement compressor is noisy as well but only at idle, just like the other. Sounds like a loud metallic rattling/buzz. Off idle and at speed the noise goes away and everything is fine.
Pressures are 25 psi low side, 175-180 psi high, vents are blowing cold even with only 30oz. of the required 3.25lbs refrigerant.
Any ideas, low oil perhaps?
